There is nothing apparently different between the two symbols; even with a text editor I can not determine any difference that may be causing this behavior.
In the official libraries REF** is used in the Silk layer, %R in the Fab layer. But when you look at the view (the fp editor or the board editor), you see REF** in both layers until the footprint receives the reference designator from eeschema.
I have a development version here, but the rules should be the same.
I don’t think this matters. At least not if used in the real reference field. It would matter in the user text field. (Meaning in the second reference field)
In the footprint editor yes. In pcb_new only if the footprint has no connection to a symbol (meaning if you manually added the footprint to the board) And in that case you would have both shown as Ref**, not one as U1 and one as Ref**
Text in the one that does not work as expected:
(fp_text reference REF** (at -0.1 -3.9) (layer F.SilkS)
(effects (font (size 0.762 0.762) (thickness 0.127)))
I should pay more attention to original posts; I can see the screenshots are from a board.
Good you got it fixed, but we still don’t understand how it happened. Can you clarify, which one actually worked, REF** or **REF? Do you mean that one of those two possibilities didn’t work at first and when you changed it, it worked?
My mistake was not making only one change at a time. I forgot to go back and change the field in Eeschema; from “REF**” to the tilde “~” symbol that I typically use.
I have gone back and
**REF
and
REF**
seem to be interchangeable.
There was probably just some typo on my part that I just could not see.
However, THANKS! for the help; the comments really helped me to focus and get things back to normal.
