Question about import SST (two boards connected like a sandwich))
Hello everyone.
I have a few boards, and they will be connected like a sandwich.
And I want to generate from one board Silkscreen and Import it to another to precisely select the location of the holes.
What is the best way to do this? Previously, I only worked in Orcad.
Thank you for your help.
Hm…
Several ways to skin this cat, just not the way you might want to (aint that always the case?) :upside_down_face:
  1. if you know the mounting alignment beforehand you can work from a DXF file, which has got the positions and import that into every layout
  2. you can create a footprint, that has the markers where you need them and use that in every layout, similar to the DXF thing
  3. you can save the project as a template and start the other boards from that
  4. same as 3, just copying the project and using that
1/2 are more safe as the location information is being fixated, while 3/4 could introduce misalignments if you’re not very careful. Personally I used 1/2.
