Q: KiCAD PCB+Freerouter keep-out regions
Hi, I have defined keep-out zones for PCB tracks (generated by Freerouter) as rectangles in F+B Courtyard. Yest it seems its ignored by Freerouter. What is correct way to make keep-out zones?
KiCAD and Freerouter are latest stable versions.
Thanks in advance.
Andrei
Freerouter is not part of the KiCad project. It has very limited routing controls
Should work. You can examine in Freerouting the objects that were imported from DSN to see if the keepout is there.
You could also ask on their GitHub repo.
I just noticed you wrote:
Keepouts should be on copper layers, like pours, even if you are manually routing.
PS: Although keepouts can go on any layer, if you had looked at the example screenshot in the documentation:
you would have seen that F.Cu is selected.
I can understand how one could form the impression that a courtyard is to keep things out but when all fails, read the documentation.
