Introduction:
I’m planning to build a Studio Clock with 59 SMD-LED ordered in a
Circle. A ideal job for a Script, but quit hard for a newbie who just
started to use KiCad (used Eagle before) and Python Scripting (but quite
familiar with programming).
I managed to get all LED-Modules and rearrange them in a circle, that
was the easy part. Creating the Tracks wasn’t easy too, cause I
haven’t found any examples and had use pcbnew.py to help me out. I
managed to create Tracks and place them were I wanted them.
My Problem:
when I’m starting to Add Vias (with the same techniques I used for
the Tracks), the Python script runs through and the Vias are added, but
when I zoom in, KiCad crashes.
I know (or rather already experienced) KiCad will crash when your not careful where to add new Elements.
My Question
- Am I doing it the right way or am I just lucky that I had not more Problems
- Were do I have to add the Vias and who am I doing it?
Edit:
3. The Tracks are not connected to the Pads, how is it done
I haven’t got the time to look through the GUI-Source code to find the function used when I’m doing it graphical and I hope somebody can help me out so I don’t have to do it ;-).
(end Edit)
#Cad Studio Clock (2016-01-30)
# This script places leds in Clock Formation
import codecs
import pcbnew
import math
import sys
pcb = pcbnew.GetBoard()
Radius = 20
Mat = [None]*(12+1) #Index 0 stays empty to align Diod number with index
NetsInner = [1,3,4]
NetsOuter = [2,5,6,7]
mods = pcb.GetModules()
print type(mods)
#Get All Diods
print '---------------------------------------------------------------'
print '---Gathering-Diods-and-Info------------------------------------'
for modu in pcb.GetModules():
ref = modu.GetReference().encode('utf-8')
if(ref.startswith('D')):
pos = int(ref.split('D')[-1])
rot = 2*math.pi/(len(Mat)-1)*(pos-1)
padA = None
padB = None
netA = None
netB = None
for pad in modu.Pads():
if int(pad.GetPadName()) == 1:
padA = pad
netA = pad.GetNetCode()
else:
padB = pad
netB = pad.GetNetCode()
Mat[pos] = [modu,rot,padA,netA,padB,netB,ref]
print 'Read: %s, Rotation %f, NetA %d, NetB %d' % (ref,rot,netA,netB)
#Calculate and Set Positions
print '---Calculating-and-Setting-Module-Positions--------------------'
for mat in Mat[1:]:
deg = math.degrees(mat[1])
mat[0].SetOrientation((deg+90)*10)
posX = math.sin(mat[1])*Radius
posY = math.cos(mat[1])*Radius
mat[0].SetPosition(pcbnew.wxPointMM(posX, posY))
print 'Placed: Diod %s at %f, %f with rot %f' % (mat[6], posX, posY, deg)
print '---Delete-Nets-------------------------------------------------'
tracks = pcb.GetTracks()
for t in tracks:
pcb.Delete(t)
#Built Net
print '---Build-Net---------------------------------------------------'
Mat.append([None,Mat[1][1],None,None,None,None,None])
for i in range(0, len(NetsInner)):
for j in range(1, len(Mat)-1):
t = pcbnew.TRACK(pcb)
pcb.Add(t)
r = 15 - i
xStart = math.sin(Mat[j][1])*r
yStart = math.cos(Mat[j][1])*r
xEnd = math.sin(Mat[j+1][1])*r
yEnd = math.cos(Mat[j+1][1])*r
t.SetStart(pcbnew.wxPointMM(xStart, yStart))
t.SetEnd(pcbnew.wxPointMM(xEnd, yEnd))
t.SetNetCode(NetsInner[i])
t.SetLayer(31)
if Mat[j][5] == NetsInner[i]:
print 'Added: Connection to %s with Net %d' % (Mat[j][6], Mat[j][5])
c = pcbnew.TRACK(pcb)
pcb.Add(c)
c.SetNetCode(NetsInner[i])
c.SetStart(pcbnew.wxPointMM(xStart, yStart))
c.SetEnd(Mat[j][4].GetPosition())
c.SetLayer(0)
v = pcbnew.VIA(pcb)
pcb.Add(v)
v.SetPosition(pcbnew.wxPointMM(xStart, yStart))
v.SetLayerPair(0,31)
