I think I’ve figured out the details of how it works. The following experiment tests a few “MAP”-type objects. I think it works as expected. The MAP objects properly translate string to find the elements with wxString keys. However, if you use .asdict() on the MAP object, then you get a proper Python dictionary but it has wxString objects as keys. You can’t use a string as the index to the dictionary that has wxString keys, even though you can use a string as the index to a MAP that has wxString keys.
Use “Paste Plus” in the scripting console:
board = pcbnew.GetBoard()
netcode = board.GetNetsByNetcode() # pcbnew.NETCODES_MAP
netname = board.GetNetsByName() # pcbnew.NETNAMES_MAP
allnetclass = board.GetAllNetClasses() # pcbnew.NETCLASS_MAP
netclass = board.GetNetClasses() # pcbnew.NETCLASSES
netcode[0] # works fine
netname['GND'] # works, but the string representation (when printed) of netname just shows "NETNAMES_MAP", not the keys/values of the dictionary itself.
allnetclass['Default'] # works, but the string representation (when printed) of allnetclass just shows "NETCLASS_MAP", not the keys/values of the dictionary itself.
netclass.NetClasses() # pcbnew.NETCLASS_MAP
netclass.NetClasses()['Default'] # works fine, similar to allnetclass
netclass.NetClasses().asdict()['Default'] # doesn't work, similar to allnetclass
netcode.asdict()[0] # works fine since the key is an integer (even though it's actually a dictionary)
netname.asdict()['GND'] # doesn't work, python dictionary has wxString objects as keys.
allnetclass.asdict()['Default'] # doesn't work, python dictionary has wxString objects as keys.
And here are the results shown:
<pcbnew.NETINFO_ITEM; proxy of <Swig Object of type 'NETINFO_ITEM *' at 0x000000000bda9420> >
<pcbnew.NETINFO_ITEM; proxy of <Swig Object of type 'NETINFO_ITEM *' at 0x000000000bda9300> >
<pcbnew.NETCLASSPTR; proxy of <Swig Object of type 'std::shared_ptr< NETCLASS > *' at 0x000000000bda96c0> >
<pcbnew.NETCLASS_MAP; proxy of <Swig Object of type 'NETCLASS_MAP *' at 0x000000000bda9750> >
<pcbnew.NETCLASSPTR; proxy of <Swig Object of type 'std::shared_ptr< NETCLASS > *' at 0x000000000bda9690> >
Traceback (most recent call last):
File "<input>", line 1, in <module>
KeyError: 'Default'
<pcbnew.NETINFO_ITEM; proxy of <Swig Object of type 'NETINFO_ITEM *' at 0x000000000bda9750> >
KeyError: 'GND'
KeyError: 'Default'
This is in KiCAD (5.1.5)-3
Application: Pcbnew
Version: (5.1.5)-3, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Edit: the MAP objects work as expected in 5.-.5-3 stable, however wxString() takes no arguments, and I still believe that is a bug.
