[Python] Crash during zones fill after unfilling them
I need to hide the zones and then restore them again, so my code looks like this:
import pcbnew
def HideAndShowZones(id):
   # Look for all zones using this layer and unfill them
   zones = pcbnew.ZONES()
   print("Unfilling zones containing "+str(id))
   for e in list(board.Zones()):
       layers = e.GetLayerSet()
       if layers.Contains(id):
           zones.append(e)
           e.UnFill()
   # Refill the affected zones
   if len(zones):
       print("Filling unfilled zones")
       pcbnew.ZONE_FILLER(board).Fill(zones)
       print("Finished filling zones")
   print("\n\n")
board = pcbnew.LoadBoard('test.kicad_pcb')
# The order is important
HideAndShowZones(pcbnew.F_Cu)
# If we do it for the same layer no SIGSEGV is observed
HideAndShowZones(pcbnew.B_Cu)
This usually works, but a user found a case where you get a Segment Violation.
The board is quite complex
test.zip (1.3 MB)
And crashes using KiCad 6.0.11 or 7.0.0.
Using KiCad 7 I was able to reduce the board to just this:
test.zip (2.2 KB)
But I suspect this small version won’t crash all systems.
I’m not sure if this is a bug or I’m doing something that isn’t supposed to be done.
Note that it works for tons of PCBs, but not for this one.
Sounds like a bug to me, but probably one that can only be hit through using Python scripting. It’s still worth reporting, though.
I’ve seen weird bugs with method chaining like this. Python GC is confused about swig objects lifetime sometimes. See if assigning filler to a variable helps.
I saw strange things too, the GS.board.GetBoundingBox().GetSize() doesn’t work. Thanks.
I tried:
        zf = pcbnew.ZONE_FILLER(board)
        zf.Fill(zones)
And it also crashed.
Can you run it under gdb and post the backtrace after the crash?
Running it under gdb I’m getting:
Thread 7 "python3" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffe8bde700 (LWP 693084)]
CN_VISITOR::checkZoneZoneConnection (this=this@entry=0x7fffe8bddd38, aZoneLayerA=<optimized out>, aZoneLayerB=aZoneLayerB@entry=0x1afa870)
    at /..../pcbnew/connectivity/connectivity_algo.cpp:823
823	    for( int i = 0; i < outline2.PointCount(); i++ )
The backtrace is:
#0  CN_VISITOR::checkZoneZoneConnection(CN_ZONE_LAYER*, CN_ZONE_LAYER*) (this=this@entry=0x7fffe8bddd38, aZoneLayerA=<optimized out>, aZoneLayerB=aZoneLayerB@entry=0x1afa870)
#1  0x00007ffff58d2a32 in CN_VISITOR::operator()(CN_ITEM*) (this=this@entry=0x7fffe8bddd38, aCandidate=0x1afa870)
    at /..../pcbnew/connectivity/connectivity_algo.cpp:862
#2  0x00007ffff58d325d in RTree<CN_ITEM*, int, 3, double, 8, 4>::Search<CN_VISITOR>(RTree<CN_ITEM*, int, 3, double, 8, 4>::Node const*, RTree<CN_ITEM*, int, 3, double, 8, 4>::Rect const*, CN_VISITOR&, int&) const (this=<optimized out>, a_foundCount=<optimized out>, a_visitor=<optimized out>, a_rect=<optimized out>, a_node=<optimized out>)
    at /..../thirdparty/rtree/geometry/rtree.h:595
#3  RTree<CN_ITEM*, int, 3, double, 8, 4>::Search<CN_VISITOR>(RTree<CN_ITEM*, int, 3, double, 8, 4>::Node const*, RTree<CN_ITEM*, int, 3, double, 8, 4>::Rect const*, CN_VISITOR&, int&) const (a_node=0x1adc820, a_rect=a_rect@entry=0x7fffe8bddd40, a_visitor=..., a_foundCount=@0x7fffe8bddd34: 1, this=<optimized out>)
    at /..../thirdparty/rtree/geometry/rtree.h:568
#4  0x00007ffff58d337f in RTree<CN_ITEM*, int, 3, double, 8, 4>::Search<CN_VISITOR>(RTree<CN_ITEM*, int, 3, double, 8, 4>::Node const*, RTree<CN_ITEM*, int, 3, double, 8, 4>::Rect const*, CN_VISITOR&, int&) const (this=<optimized out>, a_foundCount=@0x7fffe8bddd34: 1, a_visitor=..., a_rect=0x7fffe8bddd40, a_node=0x1b0b070)
    at /..../thirdparty/rtree/geometry/rtree.h:580
#5  RTree<CN_ITEM*, int, 3, double, 8, 4>::Search<CN_VISITOR>(int const*, int const*, CN_VISITOR&) const
    (a_visitor=..., a_max=<synthetic pointer>, a_min=<synthetic pointer>, this=<optimized out>) at /..../thirdparty/rtree/geometry/rtree.h:203
#6  CN_RTREE<CN_ITEM*>::Query<CN_VISITOR>(BOX2<VECTOR2<int> > const&, LAYER_RANGE const&, CN_VISITOR&) const
    (this=<optimized out>, aBounds=<optimized out>, aRange=<optimized out>, this=0x7fffe8bddd6c, aBounds=<optimized out>, aRange=<optimized out>, aVisitor=...)
    at /..../pcbnew/connectivity/../connectivity/connectivity_rtree.h:115
#7  CN_LIST::FindNearby<CN_VISITOR>(CN_ITEM*, CN_VISITOR) (aFunc=..., aItem=<optimized out>, this=0x7fffe8bddd4c)
    at /..../pcbnew/connectivity/../connectivity/connectivity_items.h:438
#8  operator() (aReporter=0x0, aItemList=0x7fffe8bddd4c, aItem=<optimized out>, __closure=<optimized out>) at /..../pcbnew/connectivity/connectivity_algo.cpp:254
#9  std::__invoke_impl<long unsigned int, CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, long unsigned int&, CN_LIST*&, PROGRESS_REPORTER*&>
    (__f=<optimized out>) at /usr/include/c++/10/bits/invoke.h:60
#10 std::__invoke<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, long unsigned int&, CN_LIST*&, PROGRESS_REPORTER*&> (__fn=<optimized out>)
    at /usr/include/c++/10/bits/invoke.h:95
#11 std::_Bind<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>(long unsigned int, CN_LIST*, PROGRESS_REPORTER*)>::__call<unsigned long, 0, 1, 2>
    (__args=<optimized out>, this=<optimized out>) at /usr/include/c++/10/functional:416
#12 std::_Bind<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>(long unsigned int, CN_LIST*, PROGRESS_REPORTER*)>::operator()<>
    (this=<optimized out>) at /usr/include/c++/10/functional:499
#13 std::__invoke_impl<long unsigned int, std::_Bind<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>(long unsigned int, CN_LIST*, PROGRESS_REPORTER*)>&> (__f=<optimized out>) at /usr/include/c++/10/bits/invoke.h:60
#14 std::__invoke_r<long unsigned int, std::_Bind<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>(long unsigned int, CN_LIST*, PROGRESS_REPORTER*)>&> (__fn=<optimized out>) at /usr/include/c++/10/bits/invoke.h:113
#15 std::_Function_handler<long unsigned int(), std::_Bind<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>(long unsigned int, CN_LIST*, PROGRESS_REPORTER*)> >::_M_invoke(const std::_Any_data &) (__functor=<optimized out>) at /usr/include/c++/10/bits/std_function.h:291
#16 0x00007ffff58d34a5 in std::function<unsigned long ()>::operator()() const (this=0x1b096f0) at /usr/include/c++/10/bits/std_function.h:622
#17 std::__invoke_impl<unsigned long, std::function<unsigned long ()> const&>(std::__invoke_other, std::function<unsigned long ()> const&) (__f=...) at /usr/include/c++/10/bits/invoke.h:60
#18 std::__invoke<std::function<unsigned long ()> const&>(std::function<unsigned long ()> const&) (__fn=...) at /usr/include/c++/10/bits/invoke.h:95
#19 std::invoke<std::function<unsigned long ()> const&>(std::function<unsigned long ()> const&) (__fn=...) at /usr/include/c++/10/functional:88
#20 operator() (this=0x1b096f0) at /..../thirdparty/thread-pool/bs_thread_pool.hpp:481
#21 std::__invoke_impl<void, BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>&> (__f=...) at /usr/include/c++/10/bits/invoke.h:60
#22 std::__invoke<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>&> (__fn=...) at /usr/include/c++/10/bits/invoke.h:95
#23 std::_Bind<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>()>::__call<void> (__args=<optimized out>, this=0x1b096f0) at /usr/include/c++/10/functional:416
#24 std::_Bind<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>()>::operator()<> (this=0x1b096f0) at /usr/include/c++/10/functional:499
#25 std::__invoke_impl<void, std::_Bind<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>()>&> (__f=...) at /usr/include/c++/10/bits/invoke.h:60
#26 std::__invoke_r<void, std::_Bind<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRE--Type <RET> for more, q to quit, c to continue without paging--
SS_REPORTER*&}, long unsigned int>::<lambda()>()>&> (__fn=...) at /usr/include/c++/10/bits/invoke.h:110
#27 std::_Function_handler<void(), std::_Bind<BS::thread_pool::submit<CN_CONNECTIVITY_ALGO::searchConnections()::<lambda(size_t, CN_LIST*, PROGRESS_REPORTER*)>&, {long unsigned int&, CN_LIST*, PROGRESS_REPORTER*&}, long unsigned int>::<lambda()>()> >::_M_invoke(const std::_Any_data &) (__functor=<optimized out>) at /usr/include/c++/10/bits/std_function.h:291
#28 0x00007ffff625d38b in std::function<void ()>::operator()() const (this=0x7fffe8bdde60) at /usr/include/c++/10/bits/std_function.h:622
#29 BS::thread_pool::worker() (this=0x1af3ca0) at /..../thirdparty/thread-pool/bs_thread_pool.hpp:581
#30 0x00007ffff0252ed0 in  () at /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#31 0x00007ffff7f6fea7 in start_thread (arg=<optimized out>) at pthread_create.c:477
#32 0x00007ffff7cf2a2f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Looking at the values the problem seems to be that zoneB->GetFilledPolysList( layer )->m_polys[1] is empty.
So outline2 is a null pointer (zoneB->GetFilledPolysList( layer )->COutline( aZoneLayerB->SubpolyIndex() ) is zoneB->GetFilledPolysList( layer )->m_polys[1][0] which is 0)
Ok, I found the problem. Is in a comment of the ZONE_FILLER::Fill.
You must call board.BuildConnectivity() after filling zones.
