Prior to updating, the Python Console in PCB worked when Pasting Code. Now, I can’t paste any code, I can only Type code
Is it me/my setup/system or, is it a Bug?
EDIT: #2 Interesting… If I open the About Kicad panel and Copy Version To Clipboard, I can paste that copied text into the Console. But, I can’t paste any copied Text from Text Editor or Python IDE…
I don’t know much about Python, and even less of it’s use in KiCad, but I did: PCB Editor / Tools / Scripting Console and copied some random text into it without problems.
Application: KiCad PCB Editor
Version: 6.0.10-86aedd382b~118~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.15.0-56-generic x86_64, 64 bit, Little endian, wxGTK, xfce, x11
Date: Dec 18 2022 19:39:35
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.86.0
ngspice: 36
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Here’s vid showing it (Also, the ending of vid doesn’t show my clicking menubar and turning On the Line Numbers).
It will copy&paste stuff from the console’s namespace but, nothing copied from elsewhere…d
Follow-Up: I re-downloaded Kicad (this time from Git-Hub, previous was from CERN).
After Installing, Pasting Code/Text copied from outside the Console still does Not work, nor does the Line_Numbers visibilitiy…
