Put resistor values in symbol
Hi.
Is there any way to force resistor values inside the box like in V4 rather than at the side?
I have edited one resistor symbol to show “Val” inside the box (it is now called Val by the way) but when added to the circuit, both reference (R?) and value (Val) appear at the side and it can make a circuit look a bit cluttered especially around op-amp applications.
See picture:
Symbol as seen in the editor then, as seen on right after inserting into Eeschema.
After rotating the value and moving it, copies on left retain the new position for Val.
Query.pdf (169.1 KB)
