Push shove not working ver 6
Hi All.
I cannot get the push and shove feature in version 6. I routed some differential pairs and an doing length tuning and the meanders won’t form because push and shove isn’t working.
Also, diff pairs won’t drag together. Can someone please help?
Does Push&Shove work at all to you (e.g in simple places)?
If yes, probably you have things configured properly.
PnS is very case-specific, it’s troubleshooting requires at least screencast that illustrates the mis-behavior (while stub board with scenario to reproduce the issue is even better). So if possible, share the details of the issue you’re facing.
