Push_E-Switch_KS01Q01.wrl - missing
It often happens that the 3D model does not load, even though it seems like it should be in the library - the file path suggests so. What’s going on? Why doesn’t the program have this model?
So, as I understood: It seems this specific model doesn’t exist in the KiCad library, but the access path is set up in case someone prepares such a model, right?
Yes, a model with the correct licensing. Manufacturers models usually have a no redistribution clause
