The circuit I designed needs to convert the AC signal received from an antenna (433MHz) and rectify it to measure the amplitude of DC voltage at the R2 resistor . Here is the schematic and the Layout I made.
1- Is it a reasonable design?
2- What would you change if you were doing this?
3- Any kind of advice and criticization is appriecated
you can simplify the design to a peak follower. Single diode and then an RC.
This will will also help in keeping things small and tight, critical for this freq range
