I put together a Project Tracking Database that runs from a Kicad Simple Plugin or, as Stand-Alone.
The Goal: Use LibreOffice 6.4, and figure out work-arounds to it’s short-comings and use it as a Kicad Plugin.
The Result: Success - a Project Tracking Database that runs from a Kicad Plug-in without any problems.
The Database is very basic but, better than doing it on paper. It’s posted at SourceForge; Here’s the Link.
A user could play with it for learning, hacking or, use as-is.
FYI - I my favorite hand-coded Java-SQLite databases are able to run from Kicad too, but, File-Structure/Access would be a problem for users without ability/knowledge/toolchain of Java Programming because the db location needs hard-coding.
Gif below shows the larger of the two GUI forms…
