I’m having an issue where my KiCAD Project manager cannot open. Whenever I do open it, it just immediately closes, and I cannot get an error code or anything. The PCB and Schema work just fine.
How can I fix this? I’ve already reinstalled it several times. This is on 5.1.4 I believe, should I just update to 5.1.6?
You can try renaming your %appdata%\kicad\ configuration folder to start from scratch and see if it’s something in the configuration which causes it. But update to 5.1.6 anyways.
