Program doesn't run on MacOS Catalina 10.15 (19A487m)
Hi.
Im running MacOS Catalina 10.15 (19A487m).
Program starts but when I create a new project KiCad crashes. I can load demo projects and they run, which makes me suspect it’s an access issue.
I have gone into System Preferences\Security & Privacy and given KiCad.app full disk access and restarted Mac.
regards
David
Application: kicad
Version: (5.1.2-1)-1, release build
wxWidgets 3.0.4
libcurl/7.64.1 SecureTransport (LibreSSL/2.8.3) zlib/1.2.11 nghttp2/1.38.0
Platform: Mac OS X (Darwin 19.0.0 x86_64), 64 bit, Little endian, wxMac
wxWidgets: 3.0.4 (UTF-8,STL containers,compatible with 2.8)
Boost: 1.69.0
Curl: 7.54.0
Compiler: Clang 9.0.0 with C++ ABI 1002
USE_WX_GRAPHICS_CONTEXT=ON
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
You should report this on bug tracker.
I figured I would update this post as it was the first I found when searching for answers. I haven’t updated to Catalina yet but have been itching to do so. I have held off as I haven’t read anything about it working yet. I need to have KiCad working before I update.
Here is the corresponding bug I found on launchpad:
