When I close the program and open it again I have to define the settings again, example:
-Zoom to fit cross-probed items.
-Full-windows crosshairs
kicad 6.0.1/Windows 10 x64
Can you examine if the setting-files (pcbnew.json / eeschema.json) are written on every closing Kicad? (llok at date/time-stamp of the files)
They should be located in:
c:\Users\xxx_your_username_xxx\AppData\Roaming\kicad\6.0\eeschema.json
Maybe it helps to delete these files? (in case they are corrupted?)
Was the login-account for kicad-installation and Kicad-using the same?
I deleted it directly and now everything is fine, thank you very much
