I got two videos of a problem when trying to join two ends of diff pair. It is sometimes easier to start from both ends while routing of d_pair routing, and the make the ends meet. But I have difficulties to make them join.
Videos are short and show what happens when I try to join same nets.
In the first video it looks like “Fix all segments on click” option is enabled, and works as designed. Try disabling it. And if then you have problems routing single tracks, disable “Use mouse path to set track posture”.
In the second video, you’re trying to connect pairs of different nets, which is not supported: DSI0_D0_P/N
to DSI1_D1_P/N
I’ll try these, thanks.
Edit: But I managed to finish the board without changing settings. So testing will take some time.
I didn’t notice. It is very good that this isn’t supported.
