I have a problem that are two hierarchical labels are connected but KiCAD ignores that connection. I made a video from it:
How can I fix this? I already deleted the labels created new ones and did a new connection. Nothing helps except a connection outside of Load_sw.
Kind regards,
Sphyrnidae
How can I fix this?
Only with bugfixing the sourcecode. This bug is tracked in issue wiring subsheets with multiple internally connected hierarchical labels: connection incomplete (#14818) · Issues · KiCad / KiCad Source Code / kicad · GitLab
I think it affects all schematics where hierarchical labels are directly connected inside of a subsheet. I see two options:
- remove the internally connected hierarchical labels from the subsheet and make the connection on the parent sheet
- place a 0-Ohm resistor (or nettie) inside of your subsheet “Load_sw” between the BP2 <–>LD2 labels.
Thank you very much for the fast answer. I hope this will be fixed soon. But what I don’t understand that it works in a minimal example:
system
Closed
4
