hi @StephanO
from the file you posted I have no issue…
The error you had is related to the absence of the setup internal section of the kicad_pcb file…
I remember that there was a kicad version which was missing to create this internal data section…
anyway in the file you posted the section is present and I can push the edge inside the pcb file without issues…
could you please test again with the file downloaded from this thread?
Thank you for your reply. After I read your post, I found the problem. I created a new KiCAD project and tried to push the sketch to the PCB before I have ever opened the *.kicad_pcb file. So there was no setup section inside the file, because KiCAD is writing the section during the first opening of the kicad_pcb-file.
The file I uploaded in my last post was already opened, so there is a setup sectoin. I didn’t know that KiCAD is doing it this way.
But after I read your comment, I realized that there is a difference between complete new files and files that were already opened… So thank you very much for bumping my nose into this.
@StephanO
thanks for your detailed feedback…
I just updated StepUp to workaround this issue.
Please consider that in general it is useful to assign, inside kicad_pcb file a mechanical reference, placing “grid origin” and/or "place origin’ in a convenient location.
I normally use grid origin, which is the default reference used also in FreeCAD as origin for sketches.
(it is possible to configure StepUp to use aux origin instead).
