Problems with 3D export
First, the Step-file misses some come components. During export I get following errors
“Could not add 3D model to C12.
File not found: ${KISYS3DMOD}/Capacitor_SMD.3dshapes/C_0402_1005Metric.wrl
Searched paths:
C:\Program Files\KiCad\6.0” and so on.".
I have added resistor and capacitor model into “C:\Users\LM10_64\Documents\KiCad\CM4IO_fdpro\CM4IO.3dshapes” folder.
Second: Should there be colors in the FreeCAD view? I haven’t. There are colors in the KiCAD viewer.
This is Win10/64 machine with
"Application: KiCad (64-bit)
Version: (6.0.0-rc1-412-gb291d6c810), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19042), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Dec 12 2021 21:00:58
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
KiCAD
I’m mostly guessing here…
As I understand it, then (if available) the .WRL models are used for KiCad’s internal viewer (and these have fancy colors), but STEP export only uses .step files (and these do not have the colors).
A lot of the default libraries have both a .wrl and a .step model for their footprints.
I have added both step and wrl files in “G:\Users\LM10_64\Documents\KiCad\CM4IO_fdpro\CM4IO.3dshapes” folder. Both C_0402_1005Metric.step and C_0402_1005Metric.wrl files are there and of course resistor files too.
Answer 2. Resistors and capacitors have3D models in “G:\Program Files\KiCad\6.0\share\kicad\3dmodels…” folder, what is the reason that they do not show in the 3D output?
STEP models can have colors and they import in FreeCAD 0.19.3 latest version and earlier - please see this thread:
https://forum.kicad.info/t/nightly-step-export-leaves-pcb-without-components-vrml-issue/32459/6?u=otoien
The only limitation I have experienced is that if transparency is defined like for LEDs it is lost on export from KiCad (might not be supported in STEP models).
Version: (6.0.0-rc1-404-gf2639e2928), release build
wxWidgets 3.1.5
Date: Dec 12 2021 09:00:02
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I tried to check if my paths and such are working, and I found a strange thing…
When I open Router/preferences/Managesymbol libraries menu, I can’t see Capacitors or resistors? Should I?
They are under Device. There are not that many capacitor symbols.
Under footprints you will find multiple capacitor folders.
In V6 there is a setting
File -Export-STEP-
A setting box appears and on the right in Other Options
Substitute similarly named models.
This should be checked as it permits the export to swap the defult .wrl with the STEP version
Thank you
I got resistors and other parts in KiCADs viewer but not so much in Step-file
I think I see the same parts missing in both (but yes colors seems to be missing in FreeCAD). The STEP file will not show empty footprints as it does not show traces. (In the FreeCAD screen shot you are apparently hovering the mouse over the board so that it has the yellow selection color. )
So perhaps there is need to check settings in KiCAD with respect to where it will look for the 3D models, both globally and for the subfolders defined in the footprints.
@LM21 you need to uncheck the ‘Enable STEP compound merge’ option in FC Import/Export STEP Preferences Tab
I was referring to @LM21’s result not mine of course. Interestingly, it does not matter if that option is ticked on or off in my installation, colors appear in both cases, but the cause is likely that the option to make compound on import does not seem to work, I always get a holding container.
OS: Windows 10 Version 2009
Word size of OS: 64-bit
Word size of FreeCAD: 64-bit
Version: 0.19.24267 +99 (Git)
Build type: Release
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: English/United States (en_US)
This is interesting. I will definitely check that unchecking when I start my Win10 machine.
About my folder and paths, yes, there may well be something wrong with them, because I have messed with them when I was installing a new component into the library. But it is not too clear because those folders are there and files in there make sense( to me, at least).
@otoien Where is that preference tab. I have looked all the menus and preferences, but I have not found that kind of screen or window. And it is so unfamiliar that I don’t think I have ever seen it here before.
Edit: This is a nightly build from yesterday (if it helps)
FC menu -> Edit -> Preferences -> Import/Output -> Step Tab
Thanks, but what is FC menu?
FreeCAD menu …
Heh. I was looking in KiCad menus
I havn’t a step menu there. OCA is the last I have. And this is the latest version I could find
That is FreeCad version Word size of FreeCAD: 64-bit
Build type: Release
I updated KiCAD only and now I can see the step option in preferences.
Edit: And when I did what was told in post 10, I can see colors now, but not much else. Many parts are missing their 3D component.
