I’m trying to make some minor tweaks to a small PCB I designed in KiCAD back in June of 2018, but when I try to read in a revised (or original) Netlist in Pcbnew it changes then adds a bunch of new components, completely messing up my design.
This is how the PCB should look:
This is the first (and only) board I’ve designed. I had it fabricated at OSH Park, and it actually works! But now I want to make a few small tweaks (add one more resistor, change a servo trace). When I open up the schematic I get this warning:
I’m not sure what that means.
When I try to load the Netlist I generated in 2018 into Pcbnew I get this mess:
This is the PCB report generated upon import:
Info: Reading netlist file "/Volumes/MacPro12 Video 1TB/PKE_Arduino/PKE_PCB_Build/PKE_PCB_Build.net".
Info: Using references to match components and footprints.
Info: Checking netlist component footprint "P1:/5ACEBE42:Connectors_Molex:Molex_PicoBlade_53398-0871_08x1.25mm_Straight".
Adding new component "P1:/5ACEBE42" footprint "Connectors_Molex:Molex_PicoBlade_53398-0871_08x1.25mm_Straight".
Info: Checking netlist component footprint "P2:/5AE28DE9:Connectors_Molex:Molex_PicoBlade_53398-1071_10x1.25mm_Straight".
Adding new component "P2:/5AE28DE9" footprint "Connectors_Molex:Molex_PicoBlade_53398-1071_10x1.25mm_Straight".
Info: Checking netlist component footprint "P3:/5AE28387:Pin_Headers:Pin_Header_Straight_1x03_Pitch2.54mm".
Adding new component "P3:/5AE28387" footprint "Pin_Headers:Pin_Header_Straight_1x03_Pitch2.54mm".
Info: Checking netlist component footprint "P4:/5AF23A58:Connectors_Molex:Molex_PicoBlade_53047-0510_05x1.25mm_Straight".
Adding new component "P4:/5AF23A58" footprint "Connectors_Molex:Molex_PicoBlade_53047-0510_05x1.25mm_Straight".
Info: Checking netlist component footprint "P5:/5AF26D93:Pin_Headers:Pin_Header_Straight_1x02_Pitch2.54mm".
Info: Checking netlist component footprint "P6:/5AF26BA5:Connectors_Molex:Molex_PicoBlade_53047-0210_02x1.25mm_Straight".
Adding new component "P6:/5AF26BA5" footprint "Connectors_Molex:Molex_PicoBlade_53047-0210_02x1.25mm_Straight".
Info: Checking netlist component footprint "P7:/5AF256D0:Connectors_Molex:Molex_PicoBlade_53047-0410_04x1.25mm_Straight".
Adding new component "P7:/5AF256D0" footprint "Connectors_Molex:Molex_PicoBlade_53047-0410_04x1.25mm_Straight".
Info: Checking netlist component footprint "P8:/5AEBE5B2:Connectors_Molex:Molex_PicoBlade_53047-1010_10x1.25mm_Straight".
Adding new component "P8:/5AEBE5B2" footprint "Connectors_Molex:Molex_PicoBlade_53047-1010_10x1.25mm_Straight".
Info: Checking netlist component footprint "Q1:/5B062396:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "Q2:/5B06240C:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "Q3:/5B06219F:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "Q4:/5B062014:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "Q5:/5B0624FA:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "Q6:/5B062569:TO_SOT_Packages_THT:TO-92_Inline_Narrow_Oval".
Info: Checking netlist component footprint "R1:/5AE278C9:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R2:/5AE27F8A:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R3:/5AE2814B:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R4:/5AF2421D:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R5:/5AE292CD:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R6:/5AE29378:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R7:/5AEBF4A2:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R8:/5AEBF517:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "R9:/5AEBEA2B:Resistors_ThroughHole:R_Axial_DIN0204_L3.6mm_D1.6mm_P1.90mm_Vertical".
Info: Checking netlist component footprint "U1:/5ACEB74C:teensy:Teensy32_Reduced".
Info: Checking netlist component footprint "U2:/5ACEB7BF:Housings_DIP:DIP-18_W7.62mm".
Adding new component "U2:/5ACEB7BF" footprint "Housings_DIP:DIP-18_W7.62mm".
Error: Component 'U1' pad '49' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '39' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '19' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '18' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '17' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '16' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '15' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '52' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '42' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '51' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '41' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '50' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '40' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '48' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '38' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '47' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '37' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '46' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '36' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '45' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '35' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '54' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '44' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '34' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '53' not found in footprint 'teensy:Teensy32_Reduced'
Error: Component 'U1' pad '43' not found in footprint 'teensy:Teensy32_Reduced'
This seems like it’s a library issue, but I haven’t touched that since 2018. It’s like it’s decided my components have a different footprint now and I have to start from scratch. I believe I created a special library on my computer for a few of the special components (Teensy). Perhaps those Molex components changed on GitHub, causing these issues. TBH, I find the whole Library management system somewhat perplexing.
I don’t see any options in the Netlist import dialog along the lines of “don’t change any components already on the PCB.”
Maybe I’d be better off just drawing the revisions manually in Pcbnew?
I’m on version 4.06 on a Mac.
Any suggestions would be greatly appreciated.
Thank you.
Shawn Marshall
