Hello everyone.
- I imported a project with a subsheet from KiCAD 5 to 6 (no errors)
- I added some elements (e.g. resistors) to the subsheet. (no problem)
- I changed the numbers and values of the newly added and old elements. (no problem)
- I saved the schematic and closed the Schematic Editor in the main project. (no problem)
- I opened the subsheet in the new Schematic Editor - not in the project. (and I see the problem:
The numbers and values have not been updated! Parts newly added in KiCAD 6 had no values). - I reopened the subsheet in the main project and added more resistors with numbers and values (no problem)
- I saved the schematic and closed the Schematic Editor in the main project again. (no problem)
- I opened the subsheet again in a new Schematic Editor - not in the project. (And I still see the problem with the update: Parts from KiCAD 5 are still not changed. I noticed that parts imported from KiCAD 5 never change numbers but lose values. Parts newly added in KiCAD 6 have no value, and parts added in point 3 already have a value - chaos in update subsheet!).
After having a look at the schematics in the text editor you can see that these values are overwritten by the section: symbol_instances. Also the values of all parts from KiCAD5 have been deleted.
I care to make sure that this data is stored correctly in the subsheet because they are separate subprojects for me and have separate PCBs. Watching manually is tiring and will lead to an error one day.
Can I hope that these problems will be fixed in the next versions of KiCAD 6?
How can I solve the subsheets update problem now?
