Hello i am Cyril from France, i am new kicad user. Excuse me for my grammaticals mistakes, i’m french.
I do not know if there is a presentation section here.
I have a problem to show the pin ground and pin 7 (vdd) for an integrated circuit 40106. There is something i must not do properly.
I can not show a picture capture because i’m new registrant on kicad forum, but you can see on this other forum my problem, it’s the last posted image:
KiCAD should automatically connect these pins to the corresponding nets (even without having them on the schematic). This works without any issues with GND but VDD might not connect properly to your used power rail for the chip. So if you for example use +5V as netname for you rpower rail and you want to connect this to the VDD pin of the chip, then just create a VDD power source somewhere and connect it to your +5V net. This way the +5V net and the VDD net become connected and are basically the same. The result is, that VDD will connect to your local power net. You should see if it worked in the PCB editor pcbnew.
