I am using Chrome and have never seen this before but if I right click in a clear bit of screen and select ‘Inspect’ I see what you do. What I believe to be a developer window opens up on the right hand side and I simply close it down the usual way ‘X’ in top right corner. Not sure if this gives you a clue but good luck
I read the forum on Firefox / Linux (home) and Chrome / Win10 (work) and have no problems. It looks to me like adBlock or something similar (if you use it) is blocking something. Usually if you can’t click anything, then quite often it’s a “cookie” notice you need to click on, but you can’t see it because it’s blocked.
As of the latest upgrade I’ll see some colored dots pulsing as the page loads when I first sign in. Not so much once I’ve logged in though. This is the Discourse software though. Not much to be done on this end though. I have a site up with it now. I’ll see if it can be turned off. @ChrisGammell ?
@kiltro Can you follow the link above? I’ll pass on any information you wish to provide them, unless by some strange chance you want to sign up for that forum too.
I noticed that too. It’s some kind of activity indicator to pacify the user. I should mention that many sites will not load correctly if Javascript is blocked. So try whitelisting forum.kicad.info in your adblocker or whatever. The only ads here will be to support KiCad.
I have firefox locked down so tight I break lots of sites. This one is pretty much whitelisted and it does fine. I have to disable notifications because it will freeze firefox for about 30 seconds and then report a fingerprinting attempt.
What about NoScript or a similar extension? (especially if you saying that in works in Incognito Mode, which I think by default disables all the extensions).
