I’m trying to install Kicad 5.1.2, following the instruction:
sudo add-apt-repository ppa:js-reynaud/kicad-5.1
unfortunately this results in the following message:
Executing: /tmp/apt-key-gpghome.2g0AQKIlAZ/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 5F1E4C625E24069D9072394F83FBAD2D910F124E
gpg: keyserver receive failed: No data
Could it be there is something changed which I don’t know of?
I tried apt update && apt upgrade but it doesn’t help.
I doubt it is a configuration error, as I don’t have any trouble importing other ppa’s. I tried it both on
Linux Mint 18.2 Sonya and Mint 19.1 Tessa. It does not work, neither from the command line nor via
the software manager.
This is the message I get from “Software Sources” when I try to add the ppa:
Meanwhile I found a workaround:
Make a file kicadkey.pgp with the content between (and including) begin pgp and end pgp from the following webpage: http://keyserver.ubuntu.com/pks/lookup?op=get&search=0x83FBAD2D910F124E
Import the key as follows:
sudo apt-key add kicadkey.pgp
sudo apt update
sudo apt install --install-suggests kicad
sudo apt install kicad-doc-en
Please don’t do that! This is nothing more than wrong. You will get installed tons of stuff you don’t need or even want. If one ore more dependencies for the KiCad binaries are missed after install the kicad package that this is simply a bug in the packaging and needs to get fixed in the packaging.
