When I try to load footprints I get the errors below.
I tried to retype the KIGITHUB path although it looked ok but the error remains.
I use KiCad V (5.1.5)-3
You shouldn’t use the github download system of KiCad at all. The 5.1 Windows installer comes with the libraries. See Library management in KiCad version 5.
A better faq article here would be I had KiCad 4 installed previosly. Now i updated to v5. Now i have some problems with the library setup
Thanks for the reply. It was indeed the V4 settings in …\AppData\Roaming that caused the probems.
I removed the kicad map there and let KiCad recreate it and now everything works fine.
Many thanks
