problem with default properties of solder fields
Hi i have a problem with setting the solder field as THT. when i set everything as through field and click ok i still have surface pad. what could be the problem ?
I upped you to basic user so you can post some screen shots. Also, under the Kicad help menu is an option to copy system information. Things like OS Version and Kicad Version are helpful.
Please explain the terms “solder field”, “through field” and “surface pad”.
