Hi
I’m having issues with connecting to a simple database. It’s my first time with SQL and ODBC.
Following SumantKhalate’s steps, I have managed to get his database working, even though I am using linux. However, when I follow the steps with my own database I can’t see any symbol:
However, in my SQL database, i can see the library of my symbols:
I think my kicad_dbl is fine because otherwise it wouldn’t appear in kicad, but I’ll show it to you just in case there’s something wrong
"meta": {
"version": 0
"name": "My Database Library",
"description": "A database of components",
"source": {
"type": "odbc",
"dsn": "",
"username": "",
"password": "",
"timeout_seconds": 2,
"connection_string": "DSN=Prueba;"
"libraries": [
"name": "Capacitors",
"table": "Capacitors",
"key": "Part ID",
"symbols": "Symbols",
"footprints": "Footprints",
"fields": [
"column": "MPN",
"name": "MPN",
"visible_on_add": false,
"visible_in_chooser": true,
"show_name": true
"column": "Value",
"name": "Value",
"visible_on_add": true,
"properties": {
"description": "Description"
"name": "Resistors",
"table": "Resistors",
"key": "Part ID",
"fields": [
"column": "MPN",
"name": "MPN",
"column": "Value",
"name": "Value",
"properties": {
Finally, I show you my odbc.ini and how I have connection with my SQL database:
[Prueba]
Description=My SqLite sample database
Driver=SQLite3
Database=/home/xxx/Descargas/Otros/sqlite/Prueba.kicad_dbl
Thanks and sorry for my English,
Miguel
