I’m building kicad from latest source https://git.launchpad.net/kicad (master branch)
Everything builds and installs but when I try to open the footprint editor I’m getting an error:
Footprint library editor failed to load:
IO_ERROR: Failed to load kiface library “/usr/local/bin/_pcbnew.kiface”.
from kiway.cpp : KiFACE() line:185
When I looked that that file and line there seems to have been a historical problem but it appears to have been fixed. I’ve possibly build without a required lib but don’t think I got an error in the build process. I’ll add my version info in case it’s useful. I’m running OpenSUSE Tumbleweed so it might be later versions of things which are causing problems. The file that is causing the problem “/usr/local/bin/_pcbnew.kiface” is at that location so I’m not sure why it can’t load the file
-rwxr-xr-x 1 root root 237628208 May 27 19:48 /usr/local/bin/_pcbnew.kiface
Application: kicad
Version: (5.0.0-rc2-35-gda6600525), debug build
wxWidgets 3.0.4
libcurl/7.59.0 OpenSSL/1.1.0h zlib/1.2.11 libidn2/2.0.4 libpsl/0.20.1 (+libidn2/2.0.4) libssh/0.7.5/openssl/zlib nghttp2/1.31.1
Platform: Linux 4.16.6-1-default x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,STL containers,compatible with 2.8) GTK+ 2.24
Boost: 1.66.0
Curl: 7.59.0
Compiler: GCC 7.3.1 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_SCRIPTING_ACTION_MENU=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=OFF
