I’m currently running KiCad 5.1.5 on Windows10, and I’m having a problem when I want to print the layouts in order to document my PCB. Actually even if I check the “Print borders and title block” option in order to have the reference frames and I let the drills option allowed, both things won’t get printed…
For the frame I tried different scales and sheet formats with no results, frame never appears.
For the holes, I’m able to get them printed only if I check either Front/Back copper layer.
Following is a screenshot of the print dialog VS the result:
Indeed, once I toggled any of the modern toolset I was able to get back the frame in the printed document. However the holes and pads still hidden unless I explicitly check either front/back copper layer to be printed…
I am using Plot to SVG. In 5.1.5 I couldn’t get right plots of bottom layers. The bug being the reason was fixed in 5.1.6. You use something else but may be the same bug concerns you.
