[SOLVED]
It was a stupid mistake on my part. I’m on a work computer and in addition to /Library/Application Support/kicad/scripting/plugins
, there’s another Library location (that’s hidden by default) specifically for my user profile where kicad was looking…
I’ll leave this up just in case it’s helpful to anyone else in the future…
Hi all,
I’m trying to use the interactive html bom plugin with kicad version 5.1.5-0-10_14 (details below) on os x 10.14.6 and I’m unable to see the plugin in the Tools > External Plugins...
list after following the installation instructions and refreshing the list (and restarting kicad).
I have verified that my user account as write access to the /Library/Application Support/kicad/scripting/plugins
path where I added the plugin folder. After searching through these forums, the only thing I can think of is that perhaps it’s a python version? It seems that I have version 3 installed and KICAD_SCRIPTING_PYTHON3=OFF
in the build info.
$ which python
/opt/anaconda3/bin/python
So assuming that this is the issue, how would I redirect kicad to use python 2? Or would it make more sense to try and build it from scratch using python 3 (and if so, how do I go about doing so)?
Thanks,
-eric
Build info:
Application: KiCad
Version: (5.1.5-0-10_14), release build
wxWidgets 3.0.4
libcurl/7.54.0 LibreSSL/2.6.5 zlib/1.2.11 nghttp2/1.24.1
Platform: Mac OS X (Darwin 18.7.0 x86_64), 64 bit, Little endian, wxMac
wxWidgets: 3.0.4 (wchar_t,STL containers,compatible with 2.8)
Boost: 1.69.0
Curl: 7.54.0
Compiler: Clang 9.0.0 with C++ ABI 1002
USE_WX_GRAPHICS_CONTEXT=ON
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
