Hello guys, I thought there are some problems after I fill the PCB with copper. For example, in F.Cu layer, at most of the trace, there is a clearance between the trace and attach layer :
But somewhere else there is no clearance at all:
This problem also exist in B.Cu layer
Is this normal ?
We can only guess what those lines on your screenshot mean. If you zip up and upload a (simplified) version of your project, we can look at what is going on inside your project.
If the track and the filled zone are on the same Net then yes it will be normal . . . what are the Nets of the track and the filled zone ?
If they are on the different nets that it also can be normal until ‘b’ is pressed.
