I notice that there is a problem with the pcb editor when you do a modification in the footprint library. The point is that I had a component in my library named SOP8 after delete the componet somehow information related with SOP8 was in the file .kicad_pdb and was generating errors for reading the netlist.
How is possible to add/remove components in a footprint library that is used without starting again the pcbnew?
Thanks,
