If I look at preview, the top and bottom borders are missing. If I print at A2 with a HP DesignJet 800 42, the borders are missing exactly as in the preview.
If I preview the A2 page in PI editor, it looks fine. If I print it A2, the top & bottom borders are lost.
If I downscale the .sch file using a Konica Minolta C554 to A3 then the borders print OK. This is done in the printer software as it prints.
I have tried changing the borders in PI Editor for A2 with no apparent change.
I am running V4.07 release build on Windows 7 Pro 64 bit.
Any ideas what else can I do to get the borders back at A2?
I thought that the Page Layout editor did a global change to the A2 page.
Just realized there is a “Page layout description File” selector on the Page editor tab in eschema.
Changed the top & bottom margin from 10 to 15mm and saved as a Page layout description File, then set the page settings to use that, and it seems fine.
On the other hand, it printed fine when plotted as a pdf then printed with the same settings on the A2 printer. That may be something that is handled by the pdf plotter.
Is there anyway to modify the global A2 print file margins?
I don’t think so, the default page layout is scaled to whatever paper size is selected. I would have suggested to create a custom page layout, which is what you already found.
That would make sense. I have noticed that my adjusted custom page has narrow side margins but normal top margins when printed A2. More tweaking required.
I only reduced the top & bottom by 5mm but it seems to have reduced the height by about 20mm on the prints. Strange!
