Hello!
I would like to change the layout position on A4 sheet. By default, it is printed in the center of the page. I would like to place a layout, e.g. in the top center position of the paper. Is it possible?
I enclose a simple sketch to illustrate problem.
Thank you.
There’s no “clean” way to do it.
There’s a workaround. When the printed graphics are positioned in the page the non-printed layers are also considered. You can simply take an unused layer, draw a long line in it and preview the print again.
Nice workaround, that’s exactly what I needed. Thank you for your help.
