Printer Output looses the drawing sheet frame
after changing to V8, my printer cannot reproduce the drawing sheet. Screen shows drawing sheet, print preview drops. Same behaviour with default and custom drawing sheet file. Any idea on how search for the reason ?
Edit (and solved): There is a tic box " print drawing sheet" what will do the job. I was never aware for this selection.
Apparently it’s turned of by default in Schematic Editor / File / Print
This is a V7->V8 pitfall ?
Cannot remember before.
Anyway, the bitmap logo is always shown as part of the drawing sheet.
Are you sure about that?
Where does that logo come from? I’ts not part of the drawing sheet.
The area where you put that logo is “reserved” for: Schematic Editor / File / Page Settings / Comments
Probably you are correct. The bitmap is not a part of the drawing sheet. The bitmap is “Logo_Open_Hardware_Small” from any unknown Kicad library and can be moved inside schematic against the sheet frame and also deleted without touching sheet frame. Finally I cannot remember how this logo came into the project what was probably started with Kicad V4 or maybe V5.
