Print: Some silkscreen is missing
Hi!
I have a problem when printing. It seems some of the silkscreen is not printed.
For example, this is my PCB:
and this is the printing preview:
These are my printing settings:
and here all project files: https://github.com/crgarcia12/electronics-homeassistant-lightscontroll/tree/main/PCB/schematics-v17
What am I doing wrong?
Thanks!
Carlos
just tested and printing-preview worked fine on my system (tested with project v17). Are you 120% sure you had the checkbox “Print according to objects tab of appearance manager” unchecked at the time of your test? (that would explain the missing silkscreen-reference-designators names).
Thanks for answering!
Yes, it is unchecked:
2022-02-26_18h32_062
[EDIT]
Now I notice that it only happens if I “Print background color”. If I do not select this option, the background is white and the silkscreen is there
Thanks!
Carlos
