Preview track traces
you can see the final track/traces of the crossover in the 3d preview?
or is there another way?
thankU
Gerbers, then Gerber viewer . . . not 100% sure what you are asking/looking for.
thank you Raptor,
I made an example on the fly, as you can see on the back of the card the separate sectors of the crossover, positive and negative, do not appear.
image|593x332
In the 3D viewer try turning the Masks off . . . see if that helps
Pefect, If I change the colors a bit it should look even better, right?
