Power Supply drawing more amperage with PCB than breadboard
Hi, first timer here, I hope Projects is the right place.
I created a dual power supply with a LT1054. On the breadboard it draws ~50mA and outputs +9V and -9V. That’s what I want.
Built on a PCB it draws over 140mA and outputs +6V and -1V. I used 0.400mm (15.75mil) traces for the power (too big?) and I use a hatched copper fill for GND on the back layer. Could that be the issue?
Thanks,
Matt
No, that doesn’t sound possible.
It sounds like a layout issue on the PCB. Or, maybe capacitors / diodes in backwards.
Hey, thanks for the fast reply! I’ll check all the caps/diodes and see how it goes. Cheers!
@3Dogs you’re a genius.
C5 and D4 were both flipped.
Datasheet to breadboard. Check
Breadboard to hand drawn schematic. Check.
Hand drawn to Schematic Editor… :derelict_house:
Thanks a ton!
I’m not a genius, I’ve just been doing this for a really long time…
Glad I could help.
There’s your problem. Start with the schematic editor and you’ll have a reference for the breadboard, and then an easy transition to a PCB.
Good tip @retiredfeline . This was my first PCB, still ironing out my workflow!
Cheers, Matt
