Hello Guy
I have again problem with schematic editor, the problem are again the power Supply.
I see that the schematic have this issued.
If are using more than 1 of the same component during the ERC checking the errors are generate
on the power connection so I have modifyed some symbol and have changed the pin form Power Input Power Output to Passive.
after this modification Kicad schematig give me the error on the powers example +12V on some +12V
give error the "input power pin not drived from nay output pin power "( translate fro Italian), this is true for all kind of power Pin, +3V3,+2V5, +5V etc…
what is the solution to fix this issue, Since now I have using Pads and dont’ have this problem
thank you
Luigi
