VDD is of type Power input, 3.3V is connected to it and i still get the error “Pin 8 not driven”. What is the problem here?
Power input pin of an IC must be directly connected to a power output pin. The 549 ohm resistor in between is seen as an “open circuit” for ERC purposes.
The recommended way to fix this in KiCad is to add a “PWR_FLAG” symbol directly to the VDD pin.
Power doesn’t propagate through components. You have to attach a power flag in the net.
Thanks everybody! That solves it.
