Possible, extremely minor, bug in the Symbol Editor
I’m looking for feedback as to whether this is a bug or something to do with my setup.
In the list of libraries in the Symbol Editor, a single left click highlights a library.
However, ONLY, on the very first attempt, and ONLY the very first time Kicad is opened for use on a day, no matter which library is chosen to be opened, always the library at the very top of the list is highlighted.
After this first attempt to highlight a library, it always works correctly for the rest of the day.
The problem does not occur in the Footprint Editor, the PCB Editor or the Schematic editor (which has a different arrangement).
What does that mean? Wait until midnight and it will fix itself? How long does the hightlight last? Or maybe it’s next boot?
I can’t replicate that on my system.
Application: KiCad Symbol Editor x86_64 on x86_64
Version: 7.0.2-6a45011f42~172~ubuntu23.04.1, release build
	wxWidgets 3.2.2
	FreeType 2.12.1
	HarfBuzz 6.0.0
	FontConfig 2.14.1
	libcurl/7.88.1 OpenSSL/3.0.8 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.52.0 librtmp/2.3
Platform: Ubuntu 23.04, 64 bit, Little endian, wxGTK, ubuntu, x11
	Date: Apr 17 2023 07:57:57
	wxWidgets: 3.2.2 (wchar_t,wx containers) GTK+ 3.24
	Boost: 1.74.0
	OCC: 7.6.3
	Curl: 7.88.1
	ngspice: 38
	Compiler: GCC 12.2.0 with C++ ABI 1017
	KICAD_SPICE=ON
The problem occurs only the first time a library in the Symbol Editor is selected (highlighted) after the computer is turned on for the first time in a day.
Rebooting the computer will not show the problem. Computer needs to be off for some time (hours).
Re phrase: After the first attempt to select (highlight) a library, the next attempt, immediately afterwards, correctly selects the required library, and every attempt to select a library in this editor is perfect until the next day, after the computer has been off for a few hours.
Oh both 7.0.2 & 7.99
As I wrote above, it is a silly little problem that has taken me weeks to isolate as I only have one chance every day.
Did you try a different mouse ?
No, but the fault is only in the list in the Symbol Editor. The PCB & Footprint editors work the same way and the problem has never occurred there.
Also, I may have spent an hour or three on Kicad, or this forum or something else before I enter the Symbol editor.
I will try a different mouse tomorrow… stay tuned :slightly_smiling_face:
As I wrote, it is a silly little problem. May not even be Kicad. That is why I posted here.
All it means is the first time I select a library in the symbol editor, I have to select twice for the first library I wish to enter. Any further libraries are selected on first click.
You only know that for sure when you understand what is causing the issue :wink: it’s good to investigate these kind of things.
