Position pins X mm from each others
Hi All,
I created a list of many pins/pads with names and sizes using Footprint Edition. later on, I want to change the distance between each pin/pad to make it 2mm instead of 1mm. I had to do this manually.
is there any automated way to position pins/pad a certain mm from each others?
Note: I am using the latest Kicad version.
If the footprints have regular arrays of pads it might be faster to regenerate them using the Footprint Wizard in the Footprint editor.
Yes. Use the “Array” tool.
It is much easier to create a new footprint using the array tool than change the distances between pads on an existing footprint.
  • Using the footprint editor, place a single pad.
  • Right Mouse click that pad.
  • Select: Create from Selection > Create Array.
This function is also available in the PCB editor.
