Position origin of pad is in a random spot
I have a pad here that says its offset by -189.249569, 125.643621 from (0,0):
But I have set the Grid origin, the Local origin (by pressing space) and Drill origin on that pad, so where does this “new origin/position” come from?
If I set it to (0,0) it places the pad somewhere to the right…
My tools/preference grid origin options:
I attach my project
test.kicad_pro (14.2 KB)
test.kicad_pcb (5.4 KB)
test.kicad_sch (2.6 KB)
KiCad Version:
Version: 8.0.1, release build
	wxWidgets 3.2.4
	FreeType 2.12.1
	HarfBuzz 8.3.0
	FontConfig 2.14.2
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
	Date: Mar 15 2024 01:52:47
	Boost: 1.83.0
	OCC: 7.7.1
	Curl: 8.5.0-DEV
	ngspice: 42
It is a bug. See: https://gitlab.com/kicad/code/kicad/-/issues/17243 and https://gitlab.com/kicad/code/kicad/-/issues/17246
If you: View > Show Properties Manager on the LH side of your screen, you will find the correct location.
