Hi guys,
So i generated my pos file and it says 6 components, can this be because of the trough hole resistors i use?
Hi guys,
not - enough - information - to - work - with …
ok, i have 94 components 4 SMD and 90 DIP/hole trough resistors. I when i generate the pos file (kicad 4.06) i get component count: 6
I have no idea why
The pos file is I think only for SMD components, but then you should have 4.
How many do you think you should have?
I think so too, if i force it i get 6. Not sure why
This will cause footprints to be listed in the .pos file.
If you got the .pos file, just open it and check which components are inside… example:
### Module positions - created on 03/17/17 11:39:52 ###
### Printed by Pcbnew version kicad (2017-02-10 revision 1bcbbb4)-makepkg
## Unit = mm, Angle = deg.
## Side : bottom
# Ref Val Package PosX PosY Rot Side
C101 100n-50V C_0805 53.7500 -70.5000 0.0000 bottom
C102 100n-50V C_0805 49.7500 -70.5000 0.0000 bottom
C103 100n-50V C_0805 47.7500 -70.5000 0.0000 bottom
C104 100n-50V C_0805 17.0000 -77.2500 0.0000 bottom
C105 100u-50V C-ALU_SMD-8.0DIA-10.5H 37.7500 -48.7500 0.0000 bottom
Thank you, thats why it does not show indeed
