I try to get the RF-plugins running on Ubuntu 16.10. I located the “/usr/share/kicad/plugins” folder and copied the plugin folder into it (using this guide)
Of course it doesn’t, you have to create them if you want to install your plugins in your home directory. KiCad doesn’t create those directories because it doesn’t install plugins by itself.
The /usr/ directory is meant for the files installed by the system administrator, either using the package manager of the system or manually if (s)he knows what he’s doing and knows it’s necessary. In this case it’s not necessary and shouldn’t be used.
My “personal” settings for KiCad are on" ~/.config/kicad/
This is a very slow pc (Passmark rating 750) and KiCad is one of the few applictions that still work well on it. My “regular” pc died 2 weeks ago and I’m still thinkging on what to replace it with.
Result is a bare KiCad installation, and I have not run any scripts for KiCad on this Linux box yet.
A directory where application specific resources has to be called something, and KiCad isn’t alone in storing scripts here. For gimp, I see a couple of directories:
Nonetheless, many applications have chosen .config. At least choice of two is better that one directory under $HOME for each application. Mozilla apps are the major holdouts in this regard.
No. Just the PCs name (e.g. = thomas). Almost all of my files and folders do not have whitespaces, points or something that may trip up certain programs
