I started to use KiCAD from ca. Version 6 or 7. The actual KiCAD version is :
Application: KiCad x64 on x64
Version: 9.0.2, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1Platform: Windows 11 (Erzeugungsversion 26100), 64-bit Edition, 64 bit, Little endian, wxMSW
Date: May 7 2025 02:29:49
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ONLocale:
Lang:
Enc: UTF-8
Num: 1’234.5
Before I used some external Plugins, which I installed through the GUI Tool on KiCAD.
When I updated KiCAD the Plugins were away. So I tried to reinstall it again with the GUI-Tool.
Unfortunately it won’t work, it tries to download it, but the Error “ZIP couldn’t be extracted” shows up, with no installation.
I tried to Re-install KiCad, clean up the remaining FIles, Data, Folder, Registry as far I could find.
Restart the OS, and re-installed KiCAD. Again it won’t install the plugins.
Then I tried to install the plugins manually, downloaded and extracted the zip files, to the Folder which the PCBEditor shows me in Tools - External Plugins- Open Plugin Folder. No Plugins, also with synchronize.
So far my Tries. Maybe someone knows a bit more, and have some hints and advises to solve this Problem ?
Thank you.
Best Regards,
John
