Plugin ICONs missing :-(
Hi all,
I just noticed my Plugin ICONs are missing . . . I was about to run KiVar to update my variants . . but the ICON is missing.
I have 3 plugins installed, as you can see . . .
but the ICONs are missing . . . :astonished:
Coincidentally, I suspect connected, I have this error poping up now, when going into Preferences after opening KiCad, probably since installing the most recent nightly (8.99.0.1896)
I’m going to install V 8.0.4 and expect this to fix my issue, I’ll report back shortly.
Well what do you know . . . .
I suspect the Nightlies have a different dependency and load a different version of the _pl_editor.dll that is not compatible with V8.x.x, installing 8.0.4 reinstalls the original DLL and I can be happy again.
I’ll raise a bug report in due course . . . I just wanted to put this up here for others to find if they have the same issue.
Issue raised . . .
Not a bug. You had a corrupt install for some reason. Concurrent version installs on windows are fully supported and functional as long as they install into separate folders. So the nightly _pl_editor.dll has zero impact on the 8.0 which has its own unique copy.
