I would think somewhere inside AppData is most appropriate? Does ProgramData require elevation?
ProgramData is actually the true path for C:\Users\Public\AppData which is an alias/symlink
Hmmm, I would want to add āLaunch pipā to the kicad launcherā¦but it would most likely be windows specificā¦which Iām not sure offends the others ~~~
I must have misunderstood our earlier conversation, I thought you were saying that even with all the ini file and env var stuff, pip needed source patching to work properly
I think this kind of technique is needed on macOS as well
Ah, it might work, the problem is we canāt set a global environment variable in windows since itās the generic python ones. And pip.ini is loaded based on working directory invocation of the shell. But itās still buggy so it needs testing. I had cases where it was ignoring me anyway, and in other cases it was not.
11 posts were split to a new topic: PCM and color themes
Hi, one of the non-functional plugins on windows is KiKit. You can trigger the behavior by running .\python.exe -m pip install git+https://github.com/yaqwsx/KiKit@v6support. It will complain about not being able to compile the regex library.
EDIT: The library is a dependency of solidpython; however, in unreleased version the dependency is removed and you can install KiKit.
KiCad doesnāt support binary dependencies in plugins. This is a known limitation, relevant on Windows.
Edit: as you can see in the discussion above. But because it was the topic, Iām not sure why you responded to me saying that.
I was responding to your question āDo you have some example plugin which tries to use a pip package which doesnāt work (one of those nonworking 30% cases)?ā - yes I have. It is KiKit. At least it was before we got rid of the problematic dependency.
