Plot as .DXF Export to Send to CNC Fabrication
In the past, I’ve used the Plot to Export DXF to send to software for laser cutters with reasonable success.
I used KiCad as a means to create a .DXF file intended to be sent to Water Jet fabrication.
KiCads .DXF in MM was interpreted as being in Inches; what should have been about 3 inches ended up being over 6.5’ FEET !!!
Was this a KiCad Export setting issue?
Or, was it the Fab House Import setting issue?
KiCad%20Fab%20Layer%20Colors
KiCad%20Fab%20Layers
DXF File Format
What would normally be done in a “real” CAD program, I was able to do with KiCad and it’s Export to .DXF feature. As stated above, the company software interpreted 78mm as 78 inches, but otherwise everything else worked and I ended up with a finished product done very inexpensively.
These designs were cut with a Water Jet machine and the results are better than I had expected. If there is any posted interest I can provide photos of how well this actually worked out in the real world with photos of the actual end cut parts.
Apparently, yes. Check plotter: We we trying to export mm but chose in · KiCad/kicad-source-mirror@85b8dd8 · GitHub which has been very recently commited by @Seth_h
