Place component on back side of board
I want to put a connector on the back side of the board. I hit f, go to the pcb board and the pins are in the same location as before. I am using a din connector with 3 rows of pins, D, B. and Z and after flipping, D, B and Z are in the same location. I am obviously doing something wrong but haven’t figured it out yet.
Can you attach the footprint file here?
What does it mean that you hit f and then go to pcb.
If you hit f not being at PCB than what do you expect to flip?
It is a 2-166648-4 connector
I meant the actual kicad footprint file.
Edit: others pointed out that you may have pressed f in wrong place. Seeing the footprint file is interesting only if flipping it correctly doesn’t work as expected.
You are aware that you do have to flip the footprint in layout?
TE_2-166648-4.kicad_mod (8.3 KB)
0
Actually, I think I know the problem – I do a flip on pcb and not in the schematic.
Thank you all
Chuck
Works for me. Make sure you have selected the footprint and not a pad in it or its text. The whole footprint should hightlight. Here’s a connector footprint that that was on the back and I’ve flipped it to the front. Because the origin is on pin 1, I have to move it afterwards if I want it in the same space and redo the copper connections of course.
As for flipping it in the schematic or not, that depends on what you want to achieve.
